Thevenin's theorem/Norton's theorem HELP!!
Discussion in 'Homework Help' started by Green024, Feb 25, 2009.
  1. Green024
    Feb 25, 2009
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    You have the correct Thevenin's Equivalent resistance.
    Your value for the Thevenin's Equivalent voltage is not correct but it appears to be that you have miscalculated since your equation is correct.
    hgmjr
  3. veritas
    Feb 7, 2008
    167
    It looks like you forgot to add R2 in your denominator.
  4. Do0gra
    Jul 30, 2008
    Connect load across terminals A and B, and use voltage divider you get
    VRL=RL/(RL+RTH) * Vth
    To find Norton's equivalent, refer to the first circuit and short terminals A & B. Use Mesh Current Analysis. Calculate the current flowing through the terminals A & B that will be In.
    Rn will be equals to Rth.
    Draw the Norton equivalent circuit, connect load to terminals A & B and use current divider to find the current across the load (IL)
