Thevenin's theorem in steady state analysis
Discussion in 'Homework Help' started by rudderauthority, Jul 25, 2011.
  1. rudderauthority
    Jul 25, 2011
    Hello all. I've been working at this problem for way too long (at least 8 hours) and I just seem to be stuck.
    I tried doing nodal analysis and didn't get correct answers, with mesh analysis I got stuck and everything I try doesn't seem to be working. I really don't understand how to hand the dern dependent source right in the middle of the problem. Any help would be greatly appreciated!
  2. narasimhan
    Member
    Dec 3, 2009
    72
    6
    You made a simple mistake. Never convert a branch which has a dependent voltage or current. i.e the branch that carries "i1" should remain as it. So you should not change "is" to a voltage source.
  3. blah2222
    May 3, 2010
    565
    33
    As the previous poster mentioned, since there is a dependant voltage source reliant on the current i1 passing through R1, it wouldn't make sense to perform a source transformation, but otherwise that may well of helped.
    First you need to find the open circuit voltage between nodes, X and Y
    1. Dependant current equation:
    i_{1} = 27 - i_{0}
    2. Going around the first KVL:
    -29i_{1} + j7.54i_{0} + 12i_{1} = 0
    -29(27 - i_{0}) + j7.54i_{0} + 12i_{1} = 0
    -783 + 29i_{0} + j7.54i_{0} + 12i_{1} = 0
    i_{0}(29 +j7.54) + 12(27 - i_{0}) = 783
    i_{0}(29 - 12 + j7.54) = 783 - 324
    i_{0}(17 + j7.54) = 459
    i_{0} = \frac{459}{17 + j7.54}
    3. Open source voltage equation:
    V_{oc} = -j26525i_{2}
    4. Going around the second KVL:
    -12i_{1} + 23i_{2} + V_{oc} = 0
    -12(27 - i_{0}) + 23i_{2} - j26525i_{2} = 0
    12i_{0} + i_{2}(23 - j26525) = 324
    i_{2}(23 - j26525) = 324 - 12i_{0}
    i_{2}(23 - j26525) = 324 - 12(\frac{459}{17 + j7.54})
    i_{2}(23 - j26525) = 324 - \frac{5508}{17 + j7.54}
    i_{2}(23 - j26525) = \frac{5508 - 5508 + j2442.96}{17 + j7.54}
    i_{2}(23 - j26525) = \frac{j2442.96}{17 + j7.54}
    i_{2} = \frac{j2442.96}{(17 + j7.54)(23 - j26525)}
    i_{2} = \frac{j2442.96}{200391 - j450952}
    V_{oc} = -j26525(\frac{j2442.96}{200391 - j450952})
    V_{oc} = \frac{64799514}{200391 - j450952}
    V_{oc} = 53 + j120
    Now you need to determine the short circuit current (i2) between nodes X and Y. The short prevents current form passing through the capacitor impedance.
    Same procedure as last time, you can check these for yourself but here are the equations to save space:
    i_{2} = \frac{12}{23}(27 - i_{0})
    i_{2} = \frac{324}{23} - \frac{5508}{23(17 + j7.54)}
    i_{2} = 2.32 + j5.22
    I_{sh} = i_{2}
    Therefore,
    Z_{th} = \frac{V_{oc}}{I_{sh}}
    Z_{th} = \frac{53 + j120}{2.32 + j5.22}
    Z_{th} = 22.96 + j0.05 ~= 23 ohms
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    I believe there's a short cut in solving the problem.
    Notwithstanding there is a dependent source one may still deduce the Thevenin impedance as
    Zth=R2||(-jXc)=23||(-j26.526k)=22.999-j0.002 Ω=22.999 @ -0.0496°
    That is, one may treat the dependent source as a short for the purposes of finding Zth looking into the XY terminals.
    In a similar manner it is convenient to note that
    Is=I1+(R1*I1-K*I1)/jXl
    Is=I1+(29*I1-12*I1)/j7.54
    Is=I1(1+17/j7.54)
    Is=27=I1(1-j2.255)
    Hence I1=27/(1-j2.255)=10.947 @ 66.08°
    Also, given R2 & -jXc form a voltage divider to extract Vth from the dependent source.
    Vth=K*I1*[-jXc/(R2-jXc)]
    Vth=12*I1*[-j26.526k/(23-j26.526k)]
    Vth=(131.36 @ 66.08°)*[0.999 @ -0.0497°]=131.36° @ 66.03°=53.37+j120 Volt
    Which agrees well enough with blah2222's values.
    More accurate values turn out to be
    Zth=22.999983 - j0.0199428 ohms
    Vth=53.361583 + j120.03316 Volts
