Thevenin's Equivalent Circuit Concept
divinesage
Joined Sep 13, 2010
7
Hello everybody, first up I'd like to say I'm very lucky to have googled and found such nice help forum. Anyway I do have a question which I need help on, it's below:
For maximum power, R(L) should be equal to R(TH) in Thevinin's Equivalent Circuit. So am I right to say that all I need to do is find R(TH) and I'll be done? I believe I have a conceptual error here as I am unable to find the answer as displayed above.
What I did was to remove all power sources from the circuit first, so then Vx would be zero since the dependent source is zero. My idea was that since Vx through the dependent source is zero, then the object that it's dependent on would also have a zero Vx. (ie. the p.d. across the 4 ohm resistor which has the Vx on it is zero and hence removed). Doing so would give me a 8/3 ohm resistance for R(TH) which is certainly not the answer.
My guess is that the dependent source plays a part in R(TH), but I was struggling over the question for a while unable to get anything resembling the 3 ohm answer above. So, any help here would be greatly appreciated. Thanks! :)
Jony130
Joined Feb 17, 2009
5,487
Well I think that to find Rth with dependent source you need first find Vth without RL and then replaced RL by a short circuit and then you need to find this short current Isc.
And finally
Rth = Vth/Isc
Ghar
Joined Mar 8, 2010
655
You can't remove Vx because it does affect Rth.
The reason is that Rth is defined as V/I applied to the port you're looking at.
Jony's method works, or you can apply either a voltage (or current) at the port and find the current (or voltage). The ratio is Rth = V/I
Jony130
Joined Feb 17, 2009
5,487
Are you sure about this method?
(100V - V1)/4Ω = (V1 - 20V)/4Ω + (V1 - 10V)/4Ω
V1 = 130/3 = 43.33V
I1 = 25/3A + 85/3A = 110/3 = 36.67A
Rth = 10V/36.67 = 0.27Ω
But if I do it "my way"
Then Rth = 120V/40A = 3Ω
divinesage
Joined Sep 13, 2010
7
V1 = 130/3 = 43.33V
Okay I understand both methods now. But I've been getting Rth = 60/30 = 2Ω for Jony's method. Been checking the polarities of Vx and I can't seem to find any problem with it. Very strange.
Using your diagram:
Current through resistor (I'll call it I3) with Vx is negative, so the dependant voltage source Vx should be negative. If I apply KVL around the topmost loop it becomes
-Vx -8I1 + 4I2 = 0
This would lead me eventually to:
I3 = I2 (which doesn't make sense because I1 + I2 = I3 and this would make I1 = 0)
The only way which I can get the correct 120V is when Vx is a positive value but then that would mean wrong polarities in the circuit.
Thanks again for the help!
Jony130
Joined Feb 17, 2009
5,487
First what I did is to fond voltage on node V1.
So for current that I draw in schematics
(100V - V1)/4Ω + ( (100V+Vx) - V1)/8Ω = (V1 - 20V)/4Ω
And Vx = V1 - 20V
And for finding Isc
(100V - V1)/4Ω = (V1 - 20V)/4Ω + V1/4Ω
divinesage
Joined Sep 13, 2010
7
From my diagram below:
I1 + I2 = I3
Vx = 4 I2
Applying KVL around leftmost loop:
100 - 4 I1 + 4 I2 - 20 = 0
20 = I1 - I2
Applying KVL around top loop:
Vx + 4 I3 + 4 I3 + 4 I1 = 0
Vx + 12 I1 + 8 I2 = 0
Since Vx = 4 I2,
12 I1 = -12 I2
I1 = -I2
I3 = 0 (doesn't make sense)
Very strange..
divinesage
Joined Sep 13, 2010
7
EDIT: Never mind, I got what Jony meant already. Kinda noobed out and forgot some basic stuff. Ugh, took me half a day to figure it out again. Thanks all!
