I am finding Thevenins and Nortons theorem really hard and confusing and i just dont know how to do it, I was hoping some of you would be able to help me.
Take a look at the material in the AAC ebook on Thevenin and Norton. Here is a link to get you started. There are also worked examples in the worksheets.
That being said, go ahead and take a look at the first schematic in the attachment.
Notice that the 0.8A current source to the left is in parallel with R1; which complies with Norton's Theorem. But, we can transform that into a Thevenin equivalent in order to simplify it with R2. So using Ohm's Law, we find the voltage transform; 0.8A x 2Ω = 1.6V. Now we have 1.6V in series with the 2Ω resistor which can be added to R2 since it is in series.
Now, you may notice that we can transform the voltage source back into a Norton equivalent in order to get the new R1 resistor in parallel with the new R2 resistor (see second schematic in attachment). Therefore, using Ohm's Law, I = E/R so I = 1.6V/4 = 0.4A. So we now have a 0.4A current source in parallel with a 4Ω resistor (and another 4Ω resistor-shown in "Equivalent #2").
Now according to the law of parallel resistors, \(\frac{1}{R1 + R2...}\) Then find the reciprocal of that. So two parallel 4Ω resistors makes a single 2Ω resistor. Then we transform that back into a Thevenin equivalent, so 0.4A x 2Ω = 0.8V in series with 2Ω. The final schematic shows the complete simplified Thevenin Equivalent.
All we have to do now is find the voltage drop across R2 = 2 x 0.8A = 1.6V. So 1.6V - 0.8V = 0.8V. The final voltage with that current is 0.8V if we had a meter on the 0.8A.
