Thevenins and Nortons. Please Help im desperate!!! :(
Discussion in 'Homework Help' started by waz, Nov 14, 2014.
  1. waz
    Nov 14, 2014
    16
    Hi Guys, This is my first time on the forum so I am unsure whether I will get any replies on this post.
    I am struggling on to do thevenins and nortons theory.
    My question is attached.
    Please help :)
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    In which part you have troubles? Please show us your attempt. Because this is your homework not ours.
  3. waz
    Nov 14, 2014
    16
    Thankyou for your reply.
    The first part of this question i have not shown, but i have already worked out the current using circuit reduction methods and found that the current passing through the 5 Ohm resistor is 0.38Amps.
    Even though I already know what the current is I have to use both thevenins and Nortons merely to check my answer is correct.
    I have no idea where to even start with either of them thats the problem.
    Reading up on both the Thevenins and Nortons has confused me massively as it involves removing various parts of the circuit etc...? :/
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    Ok, so let's start with the Thevenin's first.
    We treat 5 ohm resistor as a load so we remove this resistor from the circuit.
    And we left with this
    All you need to do now is to solve for Vth voltage.
    After you find Vth we need to find Rth for this circuit (I replace voltage source with a short circuit ).
    Please find equivalent resistance seen by looking into A-B terminals.
  5. waz
    Nov 14, 2014
    16
    This is the point that i get confused.
    To work out the Vth do i have to use circuit reduction and work from there?
  6. dalam
    Member
    Aug 9, 2014
    58
    6
    Yes you have to do circuit reduction in order to get both Rth and Vth.
    I guess Rth=2.15Ohm and Vth=2.71.
    And Rth remains the same in both cases.
    Find out Isc on your own.
  7. Jony130
    Feb 17, 2009
    3,993
    1,116
    Thevenin don't care about the method you use to find a solution for Vth. You can use any method you what/you know.
  8. waz
    Nov 14, 2014
    16
    I have no idea if any of this is correct.
    Apologies for the messy writing i am doing it in rough for now.
    does this make sense to anyone??
    And am i doing the right things??
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    Why I2 is splits into I3 and I4 ? How can it be?
    Also check your math. How can 1.92 * 0.54 equals 2.45??
    And next time write your answer here on forum.
  10. waz
    Nov 14, 2014
    16
    Sorry i was rushing and put the wrong number in the calculator.
    Is my method correct up to where i made this mistake?
    I really have no idea what to do on this, I am reading online how to find the Vth but nothing makes sense to me. Likewise with Rth?
  11. Jony130
    Feb 17, 2009
    3,993
    1,116
  12. waz
    Nov 14, 2014
    16
  13. Jony130
    Feb 17, 2009
    3,993
    1,116
    Simply use the Ohm's law and find Vth voltage.
  14. waz
    Nov 14, 2014
    16
    If i start from the beginning again
    , [​IMG]
    Am i correct to do:
    6+3=9 ohms as resistors in series are added.
    I can then do product/sum= 8 x 9/ 8+9= 4.24 ohms
    2 ohm + 4.24 ohms= 6.24 ohms.
    So the circuit will contain the supply and one resistor.
    is this correct so far?
  15. Jony130
    Feb 17, 2009
    3,993
    1,116
    Everything is ok so far
  16. waz
    Nov 14, 2014
    16
    Then do:
    It= V/Rt= 12/6.24 =1.92 amps
    Now i can calculate the current on the circuit putting back the other resistors. So i have a 12v supply, 2 ohm, 8 ohm and 9 ohm resistor.
    I1= It x 9/17
    I1= 1.92 x 0.53
    I1= 2.45 amps
    I2= It x 8/17
    I2= 1.92 x 0.47
    I2= 2.39 amps
    Is this ok so far?
  17. Jony130
    Feb 17, 2009
    3,993
    1,116
    Some kind of a new math? Check your math or use a google to do the math for you.
  18. waz
    Nov 14, 2014
    16
    Apologies.
    I1= It x 9/17
    I1= 1.92 x 0.53 = 1.01 amps
    I2= It x 8/17
    I2= 1.92 x 0.47 = 0.90 amps
    Where do i go next?
  19. Jony130
    Feb 17, 2009
    3,993
    1,116
    Vth is a voltage across 3 ohm's resistor, so all you need is to use Ohm's law and find Vth.
  20. waz
    Nov 14, 2014
    16
    V=I x R
    Vth= 0.90 x 3 = 2.7 v
    How do i go about getting the value for Rth though?
