I'm for about to do a lab about Thevenin theorem and i need to do some calculations before actually doing lab (I have just read Thevenin Theorem explanation here on Allaboutcircuit).
Here i have a circuit:
And they ask to Calculate Thevenin voltage and resistance for the network to the left of points a-b using measured resistance values (R4 is the load). Show all work. First step i know i have to remove the load in that case would be R4 and so i got:
With given circuit, the voltage between the two points where the load resistor used to be attached needs to be determined. Need help with that.
