Thevenin theorem.. Find power
Discussion in 'Homework Help' started by sonutulsiani, Mar 17, 2010.
  1. sonutulsiani
    Jan 27, 2010
    27
    Find the Power consumed by 90 Ohm Resister by using Thevenin’s Theorem
    I got the power as 2.5 watts. But I got the current as -0.166 A That's why I thought it may be wrong. Can you please do and check if my answer is correct or not?
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    As this is homework, the purpose of which is to acquaint yourself with analysis of such circuits, how about providing us with your worksheets so that we can see the method you used in getting your answer to the power across the 90 ohm resistor.
    hgmjr
  3. The Electrician
    Oct 9, 2007
    2,301
    339
    As hjmgr says, you need to show some work before we can help you.
    To motivate you, I will tell you that the result you have so far is incorrect.
  4. sonutulsiani
    Jan 27, 2010
    27
    Alright! I don't have a scanner so I took the pics from my phone. You have to zoom.
  5. The Electrician
    Oct 9, 2007
    2,301
    339
    Your first 3 equations are correct. Vth is -10 volts.
    Equation 4 has a problem. You seem to be using the bottom edge of your circuit for the reference, so when you replace the 150 volt source with a short, V1 becomes zero; there is no node V1 anymore. There is no longer any need for KCL at V1, because V1 is now ground; V1 can't possibly be 165 volts. So, get rid of that equation 4.
    Also, you aren't treating the 3I dependent current source correctly, even if there were a voltage at V1. (The left end of the 3I dependent current source is grounded now, anyway.)
    Get rid of V1 in your next two equations and try again.
  6. nubelube
    Jan 3, 2010
    16
    I haven't looked over your work carefully, but...when you use KCL at node v1, it looks like you ignore one of the branches.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    Consider your second equation ...
    -3I+(VA-V2)/60+VA/30=0 ****** equation (2)
    You should keep in mind that VA/30=I or VA=30I
    make the substitution for VA into you equation (2) above and you will
    then have V2 simply as a function of I. You'll get V2=constant*I where the constant could be negative.
    Substitute V2 as a function of I into your first equation ....
    (V2-V1)/45 +V2/15 + (V2-VA)/60=0 ****** equation (1)
    Again remember VA=30I and you know V1=150. So you'll then have an equation with the only unknown being I - for which you can then solve.
    Knowing the value of 'I' will give you VA.
    You can then find the Thevenin resistance to give the complete equivalent circuit.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Incidentally, you shouldn't be surprised if the Thevenin resistance is negative in this case. I'm still getting my head around that one. But it all seems to work out OK - mathematically speaking.
  9. The Electrician
    Oct 9, 2007
    2,301
    339
    This is his equation 3 (before simplification). He has a circled 3 to indicate the simplified version.
    This is his equation 2. His equation 1 is V1 = 150
    He actually did ok finding VA.
    This is the part he is having trouble with.
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    Thanks Electrician - I missed that he had found VA. Good work on sonutulsiani's part!
    Sometimes it's a challenge to wade through pages of handwritten work. You are more patient than I am.
    Yep - finding Rth is deceptive.
  11. sonutulsiani
    Jan 27, 2010
    27
    So now I got Vab after after solving for V2 and Va.. Va = -19 V - Vab
    So then for current I got this equation:
    10 - 19I + 90I = 0
    I = -0.1408 A
    Power = 1.785 watts ?
  12. The Electrician
    Oct 9, 2007
    2,301
    339
    That's right, but don't forget that you're supposed to use Thevenin's theorem to find the answer. So, you need to show the Thevenin equivalent.
  13. sonutulsiani
    Jan 27, 2010
    27
    Yes I did that already :)
