"Thevenin, Norton, and Maximum Power" worksheet
Discussion in 'Feedback and Suggestions' started by acalhoon, May 14, 2013.
  1. acalhoon
    May 14, 2013
    I've only just gone through a handful of the questions in the "Thevenin's, Norton's, and Maximum Power Transfer Theorems" worksheet (http://www.allaboutcircuits.com/worksheets/thev.html) I'm fairly confident the Thevenin series resistance is incorrect for question 8. The revealed answers show:
    Vth = 8.77 V
    Rth = 210.53 ohm
    Calculations for Thevenin equivalent voltage:
    R1 = 300 ohm
    R2 = 1000 ohm
    R3 = 2000 ohm
    R4 = 400 ohm
    Vth = I2 * R3
    I1(R1 + R2) - I2(R2) = 15
    -I1(R2) + I2(R2 + R3 + R4) = 0
    I1 = 271/14820 A
    I2 = 1/228 A
    Vth = 2000/228 = 8.77V
    Calculations for Thevenin equivalent resistance (Looking in method):
    ((R1 || R2) + R4) || R3 = 479.5 ohm
    Calculations for Thevenin equivalent resistance (Short circuit current method):
    Ith = I2
    -I1(R2) + I2(R2 + R4) = 0
    I1 = 21/280
    I2 = 3/164
    Rth = Vth/Ith
    Rth = 2000/228*164/3 = 479.5 ohm
  2. acalhoon
    May 14, 2013
    Another issue:
    The "note" associated with the answer for question 11 reads:
    This should read:
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Thank you, acalhoon.
    I, myself solved the exercise and initially made the same mistake as the author. That is, to first solve for the Thevenin voltage, and then use the same transformed circuit to find the resistance, not noticing that the merged resistances where unusable.
    I would also add, for Question 8, that it should read "Find the Thevenin equivalent circuit" instead of "Thevenize".
