Thevenin Help!!!
Discussion in 'Homework Help' started by CybrWb, May 2, 2013.
  1. CybrWb
    Dec 4, 2012
    14
    I'm racking my brain because I'm not sure my values are correct. Can anyone confirm for me?
    Vth = 8.76 Rth = 7297.23
    If not can you help me?
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    Your results look good to me.
    CybrWb likes this.
  3. CybrWb
    Dec 4, 2012
    14
    Thank you, I'm trying to double check myself using those values but I keep getting 7.9 V when I figure it as a complete circuit... Honestly I don't know what I'm doing... :)
  4. WBahn
    Mar 31, 2012
    18,085
    4,917
    The Thevenin equivalent is the equivalent of the circuit to the left of the two connection port circuits when nothing is connected to the right of that point. When you figure it as a complete circuit, you are analyzing a different circuit and therefore get different results. The point of the Thevenin equivalent is that you can attach the load to either the original circuit or to the Thevenin equivalent and the results, as far as the load is concerned, will be the same.
    BTW: Your 7.9V for the circuit as a whole is correct.
    CybrWb likes this.
