Thevenin Help?
Discussion in 'Homework Help' started by circuithead, Aug 1, 2006.
  1. circuithead
    Aug 1, 2006
    5
  2. paulmc
    Aug 1, 2006
    9
    sorry i cant offer any advice on the circuit,but i was wondering how i would get pictures on to this site, so everyone can view my question as many ppl dont want to open a file. cheers
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Take a look at the example that is presented in the AAC Tutorial and see it that helps you get a better feel for solving your problem.
    http://www.allaboutcircuits.com/vol_1/chpt_10/7.html/thevenin
    hgmjr
  4. circuithead
    Aug 1, 2006
    5
    Thanks. So I suppose I should deactivate the voltage source and parallel 6 and 4, then add that to 2 and parallel that to 12?
    After that, how would I find Voc? Sorry, this is just confusing me.
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Explanation of attachments at AAC
    Dave
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings circuithead,
    I noticed that your diagram indicates a voltage source that has no specific value. Did you accidentally omit the voltage or is the voltage source intended be a general voltage source with value V.
    hgmjr
  7. hgmjr
    Jan 28, 2005
    9,030
    214
    circuithead,
    I have attached a diagram of a simplified version of the circuit you are trying to analyze. Since the voltage source is ideal, it is possible to separate the 20 ohm path from the 2,4, and 6 ohm path as shown. You should now be able to work on reducing the 2,4, and 6 ohm path by applying Thevenin's Method. Once you have reduced the 2,4, and 6 ohm path to a single resistance and calculated the new Thevenin's equivalent voltage source, you will then be able to calculate the voltage at the output point and the Thevenin's equivalent resistance at the output terminals.
    This is just one of the ways to tackle this problem.
    hgmjr
  8. circuithead
    Aug 1, 2006
    5
    I did forget the voltage value, but I should be able to calculate it now.
    Thanks for all your help. :)
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    Hopefully, you will have smooth sailing from this point on.
    If you hit any more snags please let me know.
    It will be helpful if you will post your efforts up to the point at which you encounter a problem if you need any followup assistance.
    How about posting your results and I will compare them with the ones that I obtained.
    Good Luck,
    hgmjr
