Thevenin Equivalent
Discussion in 'Homework Help' started by hugoleon, Jun 16, 2011.
  1. hugoleon
    Jun 15, 2011
    13
    derive the thevenin equivalent of the circuit, I understand the equation but i don't know were to start on this equation.
    ......................r1 2.2kΩ r2 3kΩ
    -----------------------------------------1kΩ
    ..................... r3 1.2kΩ r4 300ohm
    .........9v.........................................................RL
    how do i find the rth for this equation?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Are you able to post a schematic drawing? I don't understand what you have entered.
  3. hugoleon
    Jun 15, 2011
    13
    thanks i hope this helps a little better
  4. jegues
    Sep 13, 2010
    735
    43
    Start by determining the open circuit voltage.
    To do this, remove the load and calculate the voltage across the terminals of the load.
    Note that when you remove the load, the other end of the circuit is no longer connected to ground. What effect will this have on the circuit? (Think current)
    After determining the open circuit voltage, you need to find the equivalent Thevenin resistance (Rth) as seen by the load.
    To do so, short out the voltage source and determine the equivalent resistance as seen by the load terminals.
    If you are still confused, post your work and an attempt at the solution and if need be we can further assist you.
  5. JoeJester
    Apr 26, 2005
    3,403
    1,230
    From your notes, it looks like your having difficulties determining series and parallel circuits.
  6. hugoleon
    Jun 15, 2011
    13
    my question is how do i start? i know that i have to make r1 to r4 into 1 resistor but do i divide by one or add?? what do i do to the r5?
  7. Adjuster
    Dec 26, 2010
    2,147
    300
    You would start by reducing R1 and R2 to a single resistance: R1 is in series with R2, although you seem to have written R1 // R2.
    Similarly, get the total value for R3 and R4. Now work out the parallel combination of the two branch totals.
    You now have a single resistance equivalent to R1...R4, in series with R5. Work out the total.
    You must get clear in your mind the difference between series and parallel connections, and how to calculate their equivalent values. http://en.wikipedia.org/wiki/Series_and_parallel_circuits
  8. hugoleon
    Jun 15, 2011
    13
    I combined r1//r2 r3//r4// and i get 201kohm and now and 1kohm?
  9. hugoleon
    Jun 15, 2011
    13
    i get total of 201.83ohms from r1 to r4
  10. Adjuster
    Dec 26, 2010
    2,147
    300
    I cannot see how you got the values in your last two posts. 201KΩ is very much too big, while 201.83Ω is too small.
    Try again: you are looking for an answer in the region of a few KΩ.
  11. hugoleon
    Jun 15, 2011
    13
    now i got 1.164kOhm from r1 to r4
  12. hugoleon
    Jun 15, 2011
    13
  13. jegues
    Sep 13, 2010
    735
    43
    That is correct.
  14. hugoleon
    Jun 15, 2011
    13
    is this right (9*1kohm)/(1.164kohm+1kOhm)=4.1v?
  15. jegues
    Sep 13, 2010
    735
    43
    What exactly are you trying to calculate?
  16. hugoleon
    Jun 15, 2011
    13
    DERIVE THE THENVENIN EQUIVALENT OF THE CIRCUIT SHOWN IN FIGURE 7.47a THIS IS THE QUESTION
  17. jegues
    Sep 13, 2010
    735
    43
    Yes I'm aware of that.
    I'm asking you, what were you trying to calculate?
    Was that an attempt at calculating the Equivalent Thevenin voltage (Vth)? (i.e. the open circuit voltage)
    As I mentioned in my previous post,
  18. hugoleon
    Jun 15, 2011
    13
    Yes that was for (vth)
  19. jegues
    Sep 13, 2010
    735
    43
    It is not correct.
    When you remove the load to find the open circuit voltage, the circuit is no longer complete.
    What does this mean in terms of the current flowing throughout the circuit?
    What can you conclude about Vth from this? (Hint: Write a KVL)
  20. hugoleon
    Jun 15, 2011
    13
    Ok so its 9v
