Thevenin Equivalent Circuit
Discussion in 'Homework Help' started by Hitman6267, Apr 6, 2010.
  1. Hitman6267
    Apr 6, 2010
    82
    I'm pretty sure I need to find Rth using a test source but I can't seem to do it right. (A web form tells me my answer is wrong)
    What I tried, I added a current source of 5A to node A. And deactivated the 12V source. The next step for me is to find Vx so I can add it up with R2 * 5A and get Vth. In the end I'll get Rth from, Vth/Ith. But I have failed to get a right answer.
  2. immo
    Apr 6, 2010
    8
    im not very good in this myself
    but i would use 1A as test source and than by using nodel analysis i would find the voltage at node a (lets call it Vab) then divide Vab by 1 = Vab= Rth
    try it this way, it should be correct
  3. Hitman6267
    Apr 6, 2010
    82
    got help with solving it thank you.
