Thevenin Equivalent Circuit
Discussion in 'Homework Help' started by Peter Kelleher, Apr 13, 2016.
  1. Peter Kelleher
    Apr 13, 2016
    Having difficulty solving this Thevenin question, specifically resistance
  2. Jony130
    Feb 17, 2009
    3,991
    1,116
    You must show us at least your attempt.
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    So how do you normally find the Thevenin resistance?
    Try to apply that approach and see what happens.
    Keep in mind that we can't figure out what you are doing wrong unless you show us what you are doing.
  4. ErnieM
    Apr 24, 2011
    7,437
    1,626
    This circuit is particularly simple to reduce, I did it by just looking at it. Could your problem be you do not have the mental tools to evaluate the circuit for its equivalent?
    You start by opening up any current sources, and shorting any voltage sources. Then look into the circuit for the resistance seen.
  5. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    Oh yes, and just a tiny bit of a trick question.
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    Yep, but the cookbook approach will work just fine and hopefully, in the process of doing that, the TS will observe what we can see as being obvious and then hopefully, it will be obvious to him in the future.
