A wine cooler stopped working, and I took the back off, and found the boards.
I found and unplugged one lead of a thermoelectric device that converts heat to cool, or vice versa.
When I did, things started lighting up, as though it was turned on (but it wasn't cooling)..
I tested the ohms of the device, and it started at about 38, and began to drop slowly.
When I hooked it up to 12v, all I got was a repeating beep.
When I hooked the Pos. wire to Pos. on my meter, and neg. to neg., the meter also beeped (as though a direct short).
Is the device bad? (I found some on ebay pretty cheap, and I'm pretty sure I can put it all back together correctly.)
The wine coolers sell for anywhere from $50.00 up to $500.00, so if I can get it working, that would be cool.
(pun intended)
Gary
(pun intended)
Gary
