Thermodynamic stabilitiy of colloidal systems
Discussion in 'General Science' started by boks, Jan 22, 2009.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    Are all suspensions, emulsions and foam thermodynamically unstable?
  2. studiot
    Nov 9, 2007
    5,005
    515
    Yes.
    padding padding padding.
  3. boks
    Oct 10, 2008
    218
    Which means that given enough time, the different phases in the system will disjoin? Does this also count for solid foam?
  4. studiot
    Nov 9, 2007
    5,005
    515
    To understand the answer you need to understand the following.
    All disperse systems are 'held together' by mechanical and/or electrostatic forces between particles. They are not held together by formal chemical bonds. There are sevaral possible mechanisms available and at work in different disperse systems.
    By thermodynamically unstable we mean that the (Gibbs) free energy of disassociation is negative.
    This is negative because the disperse system is characterised by a very large surface area of interaction.
    Thermodynamically
    ΔG = \gamma∂A
    Where ΔG is the change in free energy,
    \gamma is the surface tension at the interface
    ∂A is the change in surface area
    A reduction in surface area leads to negative ∂A and hence negative ΔG.
    However if we take any solid of non spherical shape this is true, but does not mean that the solid is about to spontaneously collapse into a ball.
