Thermocouple thermometer
Discussion in 'The Projects Forum' started by smelly, Oct 19, 2009.
  1. smelly
    Oct 19, 2009
    AS MY PROJECT I AM CREATING A THERMOCOUPLE THERMOMETER, I WANT IT YOU READ J TYPE. I HAVE FOUND A COUPLE OF CIRCUITS AND I HAVE AN IDEA TO TRY AND COMBINE THEM, BUT I DON'T KNOW WHERE TO START :confused:
    I HAVE ATTACHED THE DIAGRAMS I AM THINKING ABOUT TRYING TO COMBINE.
    ANY HELP WOULD BE MUCH APPRECIATED
  2. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    You forgot to attach the diagrams...
  3. smelly
    Oct 19, 2009
    these are the diagrams :)
  4. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
  5. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Your first attachment is pretty much unreadable.
    It looks like you want to replace the BC547 transistor, used as the temperature sensor in the first circuit, with the voltage output, V1, of the second circuit. If that is a ICL7106, then your V1 should go across pins 30 and 21. Check the data sheet for full details.
    http://www.intersil.com/data/fn/fn3082.pdf
  6. t06afre
    May 11, 2009
    5,939
    1,222
    Is this a school assignment, in which you must use a J type thermocouple? Depending on range your design could be simplified if you use a LM35. Just a tip.
