Thermocouple Sensor Design...help pls....
Discussion in 'General Electronics Chat' started by jrd-aac, Mar 22, 2013.
  1. jrd-aac
    Mar 6, 2013
    10
    Hello Guys…I am making a sensor design using 6 pairs thermocouple. I want the output goes like this…if only 1 over 6 thermocouples triggered a yellow led lit. And if more than 1 thermocouples triggered then a red led lit…Thanks a lot for sharing your ideas…
  2. musicalavtech
    Member
    Mar 23, 2012
    32
    The T/Cs I worked with have to be amplified. The amplified voltage can reach a threshold that a chip can trigger an LED. Sorry, not much help.
  3. bug13
    Feb 13, 2012
    1,214
    38
    My first thought would be using an MCU
  4. Jaguarjoe
    Apr 7, 2010
    770
    90
    There are many circuits for amplifying and/or linearizing a TC's output. There are also many IC's available that do the same thing probably cheaper and better.
    Once you get the TC signal out of the mud, a couple of simple comparators (LM339) will blink your LED's.
