thermocouple measurement in plasma and negative coupling
Discussion in 'General Electronics Chat' started by rufus1907, Aug 7, 2008.
  1. rufus1907
    Aug 7, 2008
    10
    hello all,
    i would like use a thermocouple to measure the temperature in a plasma and the metal where thermocouple is placed has negative polarisation(-600V). The problem here is if we get arcs, we see an overvoltage on the thermocouple which is dangerous for the measurement circuit. What kind of protection circuit can i use, to keep the voltage between 0 to 5mV?
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Can you make the temperature measurement circuit a "bird on a wire?"
    Re-phrased: Can you isolate the thermocouple amp & its supply and tie its ground to the -600V?
  3. rufus1907
    Aug 7, 2008
    10
    yes i can make it but do you think this is enough for protecting the measurement circuit?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. rufus1907
    Aug 7, 2008
    10
    thank you all for your help.
    I hope i understand it true, isolation amp limits the output voltage at -+ 10V and has gain 1. Which means if the input voltage is less than 10V, we see same voltage at the output but if the input voltage for example 500V, output voltage will be limited at 10V?
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The point of the isolation is to remove the -600 volts from the thermocouple signal. more accurately, it will allow the thermocouple to float on the -600 volt bias but pass the millivolt level signal to the measuring equipment.
  7. rufus1907
    Aug 7, 2008
    10
    is this circuit making what you meantioned before, If we connect same ground with thermocouple and isolation amp, we make the thermocouple float in the bias and receiving mV at the output of the isolation amp?
  8. vetterick
    Aug 11, 2008
    35
    Can you use a sheathed T/C?, if so connect the sheath to the -600V, if an arc occurs it would carry it back to the source.
    Rick
