Thermocouple and Resistors
Discussion in 'General Electronics Chat' started by xxxmbgxxx, Aug 15, 2007.
  1. xxxmbgxxx
    Aug 15, 2007
    Could anyone please tell me how I can calculate what resistors (or potentiometer range) is required to reduce the apparent temperature reading from a type K thermocouple to approximately half the actual reading over approximately 10 to 90 degrees (normally 0.5mV to 4.0mv over this range)
    Many thanks
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Wouldn't the most reliable way to achieve this be through software? What DAQ unit are you using?
    Dave
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    It would be helpful if you could post a schematic of your circuit to aid the members in providing you with assistance.
    hgmjr
  4. xxxmbgxxx
    Aug 15, 2007
    I am using a datalogger thermometer similar to
    http://www.omega.co.uk/Temperature/pdf/HH305_306.pdf
    I'm really sorry but I can't go into detail as to why I need this but I can't do it through software .. I need a variable resistor in series with one side of the thermocouple to give an artificial temperature (variable between approximately 25% and 75% of the actual temperature over a temp range of approx 10 to 90 deg C).
    Could anyone tell me what resistance is required or how I can calculate this
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Type K thermocouples produce voltage in approximate proportion to temperature: http://www.physik.unibas.ch/Praktikum/VPII/SternGerlach/Thermoelement.pdf
    Your dataloger will have very high input impedance, so using a series resistor will not be practical. Also, anything in series with a thermocouple, other than thermocouple wire, will adversely affect accuracy.
    Perhaps a voltage divider would work, if you are willing to sacrifice accuracy. I would put more trust in a pre-amplifier & attenuator.
  6. xxxmbgxxx
    Aug 15, 2007
    thanks for that .. so what effect would a resistor in line have please?
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It would limit the current out of the thermocouple. If the circuit reading the thermocouple output has a high impedance, the voltage might not be affected.
  8. flip
    Aug 20, 2007
    A resistor in series with a thermocouple like this is not a good idea. As thingmaker3 mentioned, the current that enters the amplifier or signal conditioner is very small, therefore the resistor will have very little effect. This is why the 'measurement circuit' requires a high impedance ... so as to not affect the voltage leaving the thermocouple. This will result in inaccurate readings.
    Even if you were successful in reducing the output to the desired value by using a resistor, you still need some method to adjust to the required range or span.
    The datalogger thermometer has a high input impedance and is designed to read thermocouples within specific ranges as determined by the logger design.
    Perhaps, a little more info about your application would be helpful.
