Thermistor
Discussion in 'Homework Help' started by sage sky, May 18, 2010.
  1. sage sky
    May 15, 2010
    7
    Hello
    i need help finding a suitable thermistor for question in my homework the teacher wants a acutal product with these ranges
    the question is below
    Describe a solid state device which can be used to measure temperature. Specify a device suitable for installation in a wall mounted sensor for measuring temperature range 5 0c to 20 oc. typical resistance at 25 0c should be less than 1.5 kΩ
    i have used a thermistor as my soild state device but i can nopt find a thermistor product number can you please help thank you
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What you do is use "thermistor" as a search term. Go into the manufacturer's sites and look for devices that meet that criterion. Here's one of several links - http://www.thermistor.com/productsNTC.php
  3. sage sky
    May 15, 2010
    7
    thank you great help oh oh how does a commissioning engineer allow for tolerance of +/- 10% in thermistors?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If you need accuracy, you look for tighter specs/interchangeable devices.
