hi,How read thermister temp from microcontroller? i want help to design ckt
The problem with making such broad generalizations is that eventually someone is going to come along and prove you wrong.Thermistors are not linear, so they are not as accurate as an LM35 sensor,also they come in different values depending on the temperature range,which micro are you using?
The US Sensor PS502J2 gives the same performance at about 1/2 the price.OTOH - With a DC95F thermistor I can get 0.1degC absolute interchangeability with *no* calibration for around $3.
What is the output of the temperature sensor?my input voltage is 3.3v for MC9S08JM32CLH (64-PIN LQFP) micro controller using...im trying interface with thermal printer mechanism ...... 9v input for thermal printer mechanism.. how to read temperature from thermal printer mechanism FTP-637MCL401
by Aaron Carman
by Jake Hertz
by Duane Benson
by Jerry Twomey
