thermal sensors
Discussion in 'The Projects Forum' started by amperahe, Aug 11, 2007.
  1. amperahe
    Aug 11, 2007
    7
    good day!
    can anyone teach me how to make a simple switch using thermal sensors.. or how can i use thermal sensor..
    knows nothing here:D
    i would be using it to automate my cooling system
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    There are thermal switches you can buy that open or close at a set temp. I have tried one by Cantherm a while back.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    There are a couple different kinds...
    Thermostats are switches which turn on or off at a given temperature. They are adequate for roughly maintaining an approximate temperature. These are inexpensive.
    Thermistors (thermally dependent resistors) change their resistance as temperature changes. Constant current through them results in a voltage either proportional or inversely proportional to temperature. They can be a part of a more complex control system.
    Thermocouples produce a tiny voltage in very accurate proportion to the temperature. These also can be part of a more complex and very accurate control system.
    If a thermostat won't provide an even enough control, a "PID" system (Proportional - Integral - Derivative)can be used to "predict" when the cooling system should turn on and off. http://en.wikipedia.org/wiki/PID_controller
    How tight a control is needed for your cooling system? (And how cold will it go? Most thermostats and thermistors wont work for super-cold temperatures. Some thermocouples will.
  4. amperahe
    Aug 11, 2007
    7
    not that super cold sir..
    im livin in the tropics.. so temperature here ranges from 30-36 degrees celcius..a bit hot
    and i will be using misting for my cooling system..should i use thermostats?
  5. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    I predict thermostats will suffice nicely!
  6. amperahe
    Aug 11, 2007
    7
    thank you very much!
