Thermal Protection
Discussion in 'Electronics Resources' started by craigfoo, Jul 1, 2013.
  1. craigfoo
    May 16, 2013
    22
    I have a heating element that I crank up to 230 C but I don't want to exceed 250 C. I have a thermistor to give me temperature feedback but I want a backup in case the thermistor fails. It needs to be small (0.25" W x 0.5"), resettable, and have the ability to wired in series with my heater element so it can break the circuit if it exceeds 250 C. A Bi-metallic switch would be perfect but I can't seem to find a small one. A thermal fuse would work if I didn't have to remove it when it tripped. Anyone have a part in mind? I've been searching around the webs and the googles for awhile.
  2. crutschow
    Mar 14, 2008
    13,508
    3,385
    What is the heater current?
  3. Kermit2
    Feb 5, 2010
    3,852
    968
  4. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I think you are pushing it a bit close with the 230 / 250 'C values.
    A typical resettable thermal fuse might have a 15'C range where it trips off, and maybe 20 to 25'C hysteresis.
    Normally the resettable thermal fuse needs to be at least 40-50'C above the regulated operating temperature. You might be able to cut it a bit closer, but risk getting issues.
