Thermal Glue
Discussion in 'General Electronics Chat' started by R!f@@, May 1, 2010.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,789
    771
    Hi guys.
    Very recently I have bought high power LED's from china. As these led's requires heat sink to be mounted, most of them have holes.
    But the 1W ones are too small to be screwed but it too gets a little hot so it too needs a tiny heat sink.
    What is the best type of glue that I could use, for transferring heat as well as a strong bond between the Led and heat sink
  2. rjenkins
    Nov 6, 2005
    1,015
    69
    I use RS Components own brand 'thermally conductive adhesive', 850-984.
    This is a two part type, paste plus solvent activator (ie. apply one to each surface).
    It's an acrylic base adhesive & the other acrylics I have used have been classed as Structural, so I'd guess it is also a high strength one.
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    Loctite sells a variety of adhesives with good thermal conduction properties. I don't have a current catalog, but have used Loctite #383 and a repairable, weaker #384. If electrical conductivity is not a problem, I suspect a metal filled epoxy (like J-B Weld) might work well and be a lot cheaper.
    There are undoubtedly other manufacturers out there. Those are just the two I have used where I needed adhesion and heat transfer.
    John
  4. Bernard
    Aug 7, 2008
    4,238
    414
    If they are clamped rather than glued, might be easier to remove in case of failure at some future time.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Here is how I did my 1W LED back when. The white stuff is thermal grease.
    The red LED and diodes is a 1 W LED simulator, the circuit in the schematics below were for a pair of flashing lights.
    I used 2 #6/32 screws, and drilled and tapped a old CPU (286) heatsink.
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Can you show us a datasheet of the power leds?
    That might give a better idea on how to mount or glue them.
    Bertus
  7. R!f@@
    Apr 2, 2009
    8,789
    771
  8. Audioguru
    Dec 20, 2007
    9,411
    896
    1) You bought no-name-brand cheap LEDs.
    2) They do not have a detailed datasheet.
    Too bad.
  9. R!f@@
    Apr 2, 2009
    8,789
    771
    Who else are making these.
    I haven't seen data sheets for leds.
    Are their any legit company that makes high power led's
  10. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  11. R!f@@
    Apr 2, 2009
    8,789
    771
    Heeeeeeeeeeeeeeeeeeeey!.
    Anybody...nobody.
    No one has used glue. surely you must have...
    c'mon
  12. Markd77
    Sep 7, 2009
    2,803
    594
    I used bolts too with a thermal pad in between led and heatsink. It works fine on the unmounted ones like you have. You just have to find tiny bolts and it's probably best to use 3 so there is no chance of slippage.
  13. mcgyvr
    Oct 15, 2009
    4,787
    974
    Try masterbond for thermal conductive adhesives.
  14. R!f@@
    Apr 2, 2009
    8,789
    771
    master bond.......hmmmm.
    where's google?
  15. jpanhalt
    Jan 18, 2008
    5,699
    909
    I have used "glue" and gave you the part numbers plus another suggestion. Did you read that post?
    Although a distinction can be made between "glue" and "adhesive," they are close enough.
    John
  16. R!f@@
    Apr 2, 2009
    8,789
    771
    oh! my bad :D
    but where can I get it
  17. retched
    Dec 5, 2009
    5,201
    313
    Riffa are you going to change you name to Reefer?
    You have no idea how to find a product supplier on the intro-net ?
    Put the pipe down. ;)
    If you need help getting something, PM me. (glue, not reefer)
  18. R!f@@
    Apr 2, 2009
    8,789
    771
    intro net? what the heck is that. :confused:
    I did search but nothing solid came up and about master bond, I emailed to them what I need.
    I do most of buying at ebay as the easiest and efficient way to pay is paypal for me, I cannot get to legit companies. So these kinda things are really hard u know. :(
    What can you get me? retched.
    And about name changing.. mod's doesn't like that. as i still have no reply about that.
  19. retched
    Dec 5, 2009
    5,201
    313
    I was just joking with the name changing.
    JB-Weld and Loctite products are all over the place here.
    IF you go to loctite website and find a product that meets or exceeds your requirements, let me know.
    I can also send you a tube of JB Weld. You can put cars together with that stuff. ;)
  20. R!f@@
    Apr 2, 2009
    8,789
    771
    will this site do
    will you be able to get anything in that site, if it is not too much trouble, I would appreciate ur help.
