Thermal Cutout - better approach, other devices?
Discussion in 'The Projects Forum' started by danl, Jun 28, 2015.
  1. danl
    Sep 24, 2013
    32
    Attachment shows a Selco disc thermostat, manual reset, opens at 250F, 125VAC, 15A, in a circuit intended to completely shut down a 3d printer if the build plate overheats.
    Tstat: http://www.selcoproducts.com/products/om-250-qc
    Need small size (this tstat is 1/2" dia.), mountable to bottom of plate, manual reset, 120VAC, preferred >15A. Less than $10-15.
    Is there a better approach? I searched for a small 20A rated manual reset disc tstat, but couldn't find one.
    Are there other devices that could be surface attached to the bottom of the plate?
    Any comments/help appreciated. Thanks.
  2. #12
    Nov 30, 2010
    16,657
    7,303
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,679
    1,295
    Snap-disc (Klixon) thermostats have always worked well for me, as long as I don't need precision control. If +/- 5 or 10 degrees is good enough and you just need to switch more power, I'd suggest using the snap-disc to control a relay with a greater contact rating but you already have a relay. You can put the thermo disc in the control side of the relay, but that won't help if the relay fails shorted.
    ak
  4. #12
    Nov 30, 2010
    16,657
    7,303
  5. MikeML
    Oct 2, 2009
    5,450
    1,066
    Look on Digikey and Mouser
  6. danl
    Sep 24, 2013
    32
