Thermal control with hysteresis
Discussion in 'General Electronics Chat' started by abuyaser, May 7, 2011.
  1. abuyaser
    Apr 20, 2011
    8
    I have built a thermal control circuit but I am trying to add the hysteresis part into it without being successful. I am using the AD22100 temp sensor and the LM393N comparator single power supply.
    Note: the npn transistor is actually inside the comparator
    I need to have it built with hysteresis but can not do it correctly
    Any help is appreciated
  2. Adjuster
    Dec 26, 2010
    2,147
    300
    Please post a schematic of your circuit.
  3. abuyaser
    Apr 20, 2011
    8
    Here is the attached file, it did not upload last time. I did voltage reference for 40 degrees Celsius and want the hysteresis to be between 40 and 35 degrees Celsius.
  4. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    Hi abuyaser,
    Q1 collector (LM393 output simulation) should not be inverted with respect to the + input.
    Calculating the value of R5, without changing your circuit configuration, made my head hurt. Since there are two 393’s in a pack, re-design your circuit as shown in the attached schematic. With this setup you can easily change the temperature set points.
    Check my calculations in case I misinterpreted something. The output driving the fan can be changed to whatever you like.
    Regards,
    Ifixit
  5. Ron H
    Apr 14, 2005
    7,050
    657
    I don't get it. Abuyaser's circuit uses an LT1017, not an LM393. I guess it is because he didn't have a spice model for LM393.
    Ifixit, I'm not sure what your circuit is supposed to do, but negative feedback around a comparator (U1a) will generally cause oscillation. Maybe you have the input pins swapped?
    EDIT: It makes sense if you swap the input pins on U1a.
  6. ifixit
    Nov 20, 2008
    639
    110
    Hi Ron-H,
    Yes you are right about the inputs being the wrong way, I made one too many edits before posting:rolleyes:. I'll replace the drawing.
    Thanks,
    Ifixit
