theremin schematic help
Discussion in 'The Projects Forum' started by markosillypig, Aug 29, 2013.
  1. markosillypig
    Thread Starter Active Member
    Jul 21, 2008
    184
    hi all
    this weekends project a THEREMIN :)
    i got a schematic off the net but just need a little help.
    is the C6 at the bottom a 1uf and is K1 an audio connector
    and finally if k1 is the connector is it to be used in conjunction with an amplifier
    that's all folks
    thanks
    marko
  2. #12
    Nov 30, 2010
    16,704
    7,354
    yes, yes, and yes.
  3. markosillypig
    Jul 21, 2008
    184
    thanks just wanted to be sure just hope the project works
  4. #12
    Nov 30, 2010
    16,704
    7,354
    C'mon back if something goes wrong.:)
  5. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    The circuit you show is basicaly a beat oscillator.
    It will produce a tone that is the difference between the two oscillators.
    A real theremin consists of 4 oscillators.
    2 are used for the pitch and 2 are used for the volume.
    On the following page, you will find some links to some "real" theremin schematics:
    http://www.thereminworld.com/schematics
    Bertus
    Griz, Metalmann and #12 like this.
  6. Ramussons
    May 3, 2013
    562
    92
    Can someone tell me What is a "Theremin" Circuit?
    Ramesh
  7. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    A Theremin is a musical instrument that is played by moving you hands.
    The sound is a bit like a violin.
    Here are a couple of videos where the Theremin is played:
    http://www.thereminworld.com/theremin-videos
    Bertus
    Treeman likes this.
  8. Ramussons
    May 3, 2013
    562
    92
    Thanks Bertus. This is really interesting !
    Ramesh
