Theory issues regarding forward and reverse biased diodes and voltages
Discussion in 'General Electronics Chat' started by Teee, Nov 11, 2012.
  1. Teee
    Nov 11, 2012
    6
    So far, from what I've studied... Current flows from the positive to the negative. Then here comes diodes, where there's forward-biased, reverse-biased, forward current, reverse current, forward voltage and reverse voltage.
    In a DC voltage, isn't there only direction of current flow? Then how would reversed voltage come about in a DC circuit? Should the voltage of a reverse-biased diode be 0? Why is there a discussion of reversed voltage? And what is how does reverse currents work?
    Seriously confused kid over here. :( :confused:
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    This is a physics forum. We have an electronic chat forum, as well as a project forum, so I am moving your threads over there.
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    This imagines explain everything
    Forward-biased diode
    Reverse-biased diode
    Diode allows current to flow in one direction (called the diode's forward direction), while blocking current in the opposite direction (the reverse direction).
    Any more questions?
      File size:
      8.5 KB
      108
      File size:
      8.5 KB
      113
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    I add that when diode is reverse biased
    Only small reverse current will flow and this current is essentially constant no matter what reverse bias is applied. If reverse bis voltage increased sufficiently beyond reverse breakdown voltage. Diode will begin to pass a large reverse current which can destroy the diode.
      File size:
      19.5 KB
      407
  5. tshuck
    Oct 18, 2012
    3,531
    675
    I think it's important to note for the OP that if he/she looks at the ebook of AAC that it follows the electron path current flow, which is opposite to the conventional current flow as seen above...
  6. JMac3108
    Aug 16, 2010
    349
    66
    It sounds to me like the OP is just having trouble with terminology.
    These terms can be used in other ways, but generally...
    Bias means voltage. Forward bias means that the voltage is applied to a device (such as a diode) with the correct polarity for current to flow (positive to anode, negative to cathode).
    Reverse bias means that the voltage is applied to the device (such as a diode) with the opposite polarity, such that current will not flow (negative to anode, positive to cathode).
    The term reverse current may have bothered you. In the case of a diode, all this means is that with the voltage applied in the reverse bias direction, such that current doesn't flow, there is actually a small leakage current that gets through the diode.
