Theoretical limits on this amplifier design?
Discussion in 'General Electronics Chat' started by *synonymous*, Apr 22, 2016.
  1. *synonymous*
    Nov 29, 2013
    24
    Hello
    I am intending on using this particular audio amplifier design using a 30vct transformer which i believe is well within it's limits, however, I am curious as to what the possible limits are. Adequate heat-sinking assumed, could I use a transformer with dual 24 secondaries? What would be the first part to cause trouble?
    Thanks all
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    You need to check if Vce_max for all the transistor is larger than 2Vcc.
    *synonymous* likes this.
  3. crutschow
    Mar 14, 2008
    13,487
    3,371
    Note that the DC output voltage of a rectified AC voltage is near 1.4 times the AC RMS value.
  4. recklessrog
    Member
    May 23, 2013
    346
    102
    Either take a look at the manufacturers spec sheet, or connect it to a variable psu, wind the voltage up until something goes pop and you will have found the answer to your question!
