The way to utilize UART serial interface on Android system
Discussion in 'Embedded Systems and Microcontrollers' started by jeepcoon, Oct 12, 2016.
  1. jeepcoon
    Oct 9, 2016
    Hi all,
    I am new here, and i would like to talk about the specification of How to utilize UART serial interface on Android system today.
    Introduction
    Here is a page describing the different ways you could use to connect an Android device to an RS232 peripheral.
    Solution 1
    • pros
      • No need for external API, the Android SDK provides the class BluetoothSocket
      • No need for hardware modifications
      • hardware flow control is supported
    • cons
      • Bluetooth consume battery
      • high latency
      • low bandwidth
    • API
    Solution 2
    • pros
      • USB to RS232 adapters are cheap and easy to find
      • no hardware modification needed
      • no external battery needed
      • low latency
      • high bandwidth
    • cons
      • your Android device needs an USB host connector (most tablets have one, but phones usually don't)
      • your may need to root your device in order to change /dev/ttyUSB0 file permission, and to load a kernel module.
    • API
      • android-serialport-api
    Solution 3
    Solution 4
    • pros
      • compatible with any Android device with an USB slave connector, i.e. 99.9% of the Android devices.
      • no need to root your phone
      • low latency
      • high bandwidth
      • you may use other GPIOs of the microcontroller at the same time
    • cons
    • API
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    So is there a question in all of this?
  3. atferrari
    Jan 6, 2004
    2,663
    784
    No question at all. If you wait enough, somebody will end offering / suggesting something through a link.
