Do you know those cheesy vampire movies where as soon as vampire shows up, the protagonist pulls out a wooden cross? Yeah, I think we will use Superposition for the cross.Do you know how to do superposition?
If the batteries oppose each other, then why do you add them together to calculate loop current with 60 volts?as they appose each other it would give a net voltage of 10V.
But doing superposition means calculating the loop voltage drops twice in order to add the voltages. Better to add the battery voltages once, then calculate the loop voltage drops once.Here's how you solve it with superposition.
It's easier for me to calculate the voltages drops twice and subtract once as compared to calculating the voltages drops once and figuring out how to add/subtract the battery voltages to get the correct answer (which is what the OP is having a problem with).But doing superposition means calculating the loop voltage drops twice in order to add the voltages. Better to add the battery voltages once, then calculate the loop voltage drops once.
Superposition violates the Law of Wally.
This seems to be contrary to convention: https://en.wikipedia.org/wiki/Electronic_symbolHere's how you solve it with superposition.
The small plate of the batteries are positive.
Calculate the voltage across the meter with Bat2 replaced by a short circuit.
Then replace Bat2 and calculate the voltage across the meter with Bat1 replaced with a short circuit.
(If it helps your calculations, you can ground the minus side of the meter.)
Add the two voltages (observing the polarity) and you will have the correct answer.
Yup, I got it backwards.This seems to be contrary to convention:
Get in the habit of properly tracking your units. You should haveWhat I do know is
I = (25 + 35) / (9 + 4)
I can work out potential difference across the resistors but I'm confused what I'm subtracting it from and the direction of stuff. I assumed the 25V battery is going in the direction of the 9ohm resistor but as there isn't any voltage drop at the junction of the open circuit, I always think that shouldn't all 25 volts go down there? Then the same for 35V as it goes the other way...And as they appose each other it would give a net voltage of 10V...
As you can see I'm a mess ;x help
The resistors notation is confusing but from the result shown by volt meter, the resistances of R1 and R3 should be 4 ohms and 9 ohms, respectively not 4R and 9R as symbolic values.Get in the habit of properly tracking your units. You should have
I = (25 V + 35 V) / (9R + 4R) = (60 V) / (13R)
Why ??The resistors notation is confusing
For this case (4Ω and 9Ω) we have R = 1Ωthe resistances of R1 and R3 should be 4 ohms and 9 ohms, respectively not 4R and 9R as symbolic values.
That's possible. A common notation on schematics (particularly in days past) was to use the units multiplier (m. k. M. etc) as the decimal point and, if there was no multiplier, use R (for a resistor) instead.The resistors notation is confusing but from the result shown by volt meter, the resistances of R1 and R3 should be 4 ohms and 9 ohms, respectively not 4R and 9R as symbolic values.
Why ??
For R you can pick any real number you like.
For R = 2.2kΩ we have
4R = 4*2.2kΩ = 8.8kΩ
9R = 9*2.2kΩ = 19.8kΩ
Oh, yes, my mistake. You are right. The result remains the same no matter which value of R.That's possible. A common notation on schematics (particularly in days past) was to use the units multiplier (m. k. M. etc) as the decimal point and, if there was no multiplier, use R (for a resistor) instead.
I didn't know that!
In this case it doesn't really matter since you will get the same results regardless of what you choose for R.
by Duane Benson
by Aaron Carman
by Jake Hertz
by Duane Benson
