the voltage of resistor parallel with wire >>>/!\ Help please/!\
Discussion in 'Homework Help' started by !!Miss.EE!!, Oct 18, 2007.
  1. !!Miss.EE!!
    Thread Starter Active Member
    Oct 17, 2007
    38
    Hi all , I'm new member here and I'm really happy I found this amazing site. :D
    I don't know how to start since it is my first time writing here, However. I hop I'll do something to this forum in return. ^___^
    I have a problem in standing why the voltage must be zero for R=2K in the figure below (I mean Vo)... (Note: I simulate the circuit using Orcad that why I knew it is 0 V ) but why I really don't know . Can you please help me ??!!)
    Further I know when resistor is parallel with wire(short circuit ) the current through that resistor is equal zero , is it by somehow that is the reason the voltage through that resistor is equal to zero too!!) ....:confused:
    :confused:
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    The image is too small to read.
    Dave
  3. !!Miss.EE!!
    Oct 17, 2007
    38
    /!\click on it please /!\
  4. recca02
    Apr 2, 2007
    1,211
    the image is too large :D
    havent solved yet but it seems it should not be zero.
    however a short circuit in parallel isnt the only reason for voltage difference acrosss a element to be zero.
    sometimes the voltage across to element is same(like in wheatstone circuit) and hence the voltage difference is zero.
  5. !!Miss.EE!!
    Oct 17, 2007
    38
    thanks but we didn't take wheatstone circuit yet T___T
  6. recca02
    Apr 2, 2007
    1,211
    where did the original circuit go?(i didnt mean to complain b4)
    by the way i dont think answer shud be zero for that circuit.
    by wheatstone circuit example i meant there are some times conditions that voltage drop across elements is such that there are points in circuit whose potentials are same and hence no potential difference exist between them.
  7. !!Miss.EE!!
    Oct 17, 2007
    38
    Ok sorry I didn't say it before
    But I have to use superposition theorem
  8. chulangj
    Oct 11, 2007
    you have shorted out the resistors to the output and form a new path for the current to pass. The voltage across this wire is very very very small and would read zero. A pic of the new circuit is shown here
  9. !!Miss.EE!!
    Oct 17, 2007
    38
    this is the Q...I solved the other two cases ...just the one above Couldn't understand it.
  10. !!Miss.EE!!
    Oct 17, 2007
    38
    Isn't like what I said in my first post????:confused:
  11. !!Miss.EE!!
    Oct 17, 2007
    38
    Thank you Very much ;)>>>> I got it >>>> :D
  12. recca02
    Apr 2, 2007
    1,211
    i thought u meant o v in the actual problem
    anyways for the above case like u said the resistances are in parallel to a short hence the current thru 2 +2 ohms loop is zero so no votage drop across the 2 ohm resistor.
  13. !!Miss.EE!!
    Oct 17, 2007
    38
    Vo is across one resistor with 2K which is also parallel with the another 2K, so V across them is equal , hence it is zero 'cause they are parallel with wire(short) ... right !!!:(
  14. recca02
    Apr 2, 2007
    1,211
    that will be a bit confusing way to look at the circuit .
    actually that way if u consider the circuit then the two resistors of 2K have a terminal floating.
    so the answer in any case is that all current flows thru the parallel short circuit and hence no current flows thru the 2k resistances and so no P.D.
    or u can also say that since voltage diff across a short is zero hence voltage drop across the 2k resistors in series(in this case) is zero.
    there are a lot of ways to look at this more than i can even post right now.
  15. !!Miss.EE!!
    Oct 17, 2007
    38
    this is the original question::
    and I approached this case and now I'm confused again:
    first is the node I circled is the same???
    then some one can help me find Vo in detail please; 'cause each time something come up on my mind :mad:
  16. recca02
    Apr 2, 2007
    1,211
    they are all same
    if u really want to solve it the old fashioned way use kvl
    just take those three squares as separate loops.
  17. !!Miss.EE!!
    Oct 17, 2007
    38
    some thing new .... ( sorry but I don't give up till all my idea is finished)
    I redraw the circuit (don't LAUGH )
    now it is clear both of 2K resistors are with open node >>>> Thats why they have Zero volt. ( it is a question) -____-!!
  18. recca02
    Apr 2, 2007
    1,211
    that is what i meant.
    the more thought u give the better u will arrive at same conclusion but with new methods and will have much more clearer idea.
  19. !!Miss.EE!!
    Oct 17, 2007
    38
    thank you very much llllllllllllllllllllllllllllllllllllllllllllllllll 100%:D
  20. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Miss EE,
    Complete all the steps of the superposition. Just because the first step you've done has 0 as Vo doesn't preclude you from having an output when you add the remaining steps.
