The voltage of a clock pulse ???
Discussion in 'General Electronics Chat' started by CIX, Aug 27, 2008.
  1. CIX
    Aug 27, 2008
    I need to construct my own clock pulse with only batteries and a push button switch but am unsure of the voltage. The IC I need to pulse is the 74LS76 j-k-flip-flops, the frequency is not important.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The voltage levels on TTL logic are 0 and +5 volts. LS is good with about .8 volts for low and 4.2 volts for high.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The input voltage levels of TTL and LS-TTL gates is a low of 0.8V or less (0.4V is good) and a high of 2.0V or more (2.4V from a TTL output or 2.7V from an LS-TTL output are good.
