I have 7805 regulator. I know its output is 5v
What is its maximum input?
any comments will help. thank you!
I used 9v input. is there current in it?The 7805 data sheet (just Google "7805" to find one) will give you that info, under Absolute Maximum Ratings. For the Fairchild 7805 (the first one that comes up on Google), its 35 volts.
Ummm... not sure what you mean? 9V will certainly suffice as an input for the 7805, either from a 9V battery or from some other power source, such as a 9V DC wall-wart.I used 9v input. is there current in it?
by Jake Hertz
by Aaron Carman
by Duane Benson
by Jake Hertz
