thatoneguy
- Joined Feb 19, 2009
- 6,359
From looking at the graph of the solved problem with only one resistor, the dashed line appears to be the voltage the system "levels out" to. This would imply that E is a voltage source.
The solution, in non-math speak, is that C1 charges through R1 to E volts when the switch is connected so the left hand side is the complete circuit.
When the switch state is changed, R1 and the voltage source are completely removed from the solution.
At the switch change, the capacitor, charged to E, will discharge through the "leaky" capacitor C2, with R2 being the leakage.
The end Voltage after a period of time will be zero, with all energy dissipated by R2.
Does this make sense, or am I on the wrong track before I go further?
