The Unified Field Equations in Disguise!
Good stuff from Miles Mathis.
Mass is Charge Volume and Charge Radius, a combination field effect.
Check it out and learn how Coulombs Constant and Newtons Constant are really the UFT.
So if the universe is expanding, then the acceleration force creates gravity...via expansion of the radius, just turn Einsteins curvature of space inside out...and voila...it all fits.Abstract: I will show that we have had not one but two correct and successful unified field equations for centuries.
Both Newton’s and Coulomb’s famous equations are unified field equations in disguise. This was not understood until I pulled them apart, showing what the constant is in each equation and how it works mechanically.
A unified field equation does not need to unify all four of the presently postulated fields. To qualify for unification, it only has to unify two of them. The unified field equations that will be unmasked in this paper both unify the gravitational field with the electromagnetic field. This unification of gravity and E/M was the great project of Einstein and is now the great project of string theory. But neither Einstein nor string theory has presented a simple unified field equation. As time has passed this has seemed more and more difficult to achieve, and more and more difficult math has been brought in to attack the problem. But it turns out the answer was always out of reach because the question was wrong. We were seeking to unify fields when we should have been seeking to un-unify them. We already had two unified field equations: which is why they couldn’t be unified. We were trying to rejoin a couple that was already happily married.
Yes, both Newton and Coulomb discovered unified field equations. That is why their two equations look so much alike. But the two equations unify in different ways. Newton was unaware of the E/M field, as we know it now, so he did not realize that his heuristic equation contained both fields. And Coulomb was working on electrostatics, and likewise did not realize that his equation included gravity. So the E/M field is hidden inside Newton’s equation, and the gravitational field is hidden inside Coulomb’s equation.
http://milesmathis.com/uft2.html
