And BTW, it's on sale for $499.99, not $99.
http://www.harborfreight.com/garage...nch-x-10-inch-precision-mini-lathe-93212.html
Here's some pics of mine, I haven't used it in at least 5 years. Looks like the gears need some lubeYes go ahead and post em up. I can't get enough tool pron. Is yours a craftsman 109?
3 jaw would be nice, but I wouldn't want to give up the 4 jaw either. I don't plan on machining exclusively circular objects.
I was reading a discussion on the hobby machinist forum about HF tools, and gained a new perspective. Anything you buy from there, should be purchased with the understanding that you are actually buying a kit; some disassembly, reengineering, and reassembly required. If you walk into it with that mindset, and not the mindset that you're buying a "ready for operation" tool, then you can still realize value in it and feel good about your purchase.Sure that's a good point their little lathes are just Chinese no-name junk. I've seen a few instances where people have bought them and fixed them up, which is pretty much a must for any cheap new lathe or mill. And second hand tools too.
Fortunately a lof of stuff on the little Chinese lathes is adjustable, mine needed the main chuck runout fixing, and I was able to get it pretty good. The tailstock was badly out of alignment and it adjusted ok but it is not perfect, to get it closer will need some machining.
You should check out the metalworking forums there should be threads on testing and aligning lathes, maybe even your exact model.
Thread starter | Similar threads | Forum | Replies | Date |
The ultimate geek clock | General Electronics Chat | 104 | ||
E | Microcontroller Ultimate Projects Board Help | Microcontrollers | 5 | |
Designing the Ultimate Continuity Tester | General Electronics Chat | 28 | ||
Ultimate power tool(s) (holy crap I got almost a whole machine shop) | Off-Topic | 11 | ||
J | Ultimate power supply | Power Electronics | 3 |
by Jake Hertz
by Jake Hertz
by Aaron Carman
