The transistor common emmiter amplifier
Discussion in 'General Electronics Chat' started by eyj, Oct 27, 2004.
  1. eyj
    Oct 27, 2004
    a few questions on this ckt. does the change in Vcc affect the bias condition of the transistor? if it did, how? does the amplifier continue to produce an output when Vcc is switched off? why?
  2. mozikluv
    Jan 22, 2004
    when Vcc is change whether up or down but the base, emitter & collector resistors are not replaced, the bias condition will naturally change. change of temperature will also change the bias condition.
    when you switch off supply, conduction completely stops unless you have a cap connected which will continue to discharge after the supply is cut off.
    what does your book say about biasing? :)
