The transistor as a switch errors
Discussion in 'Feedback and Suggestions' started by SgtWookie, Feb 10, 2010.
  1. SgtWookie
    Thread Starter Expert
    Jul 17, 2007
    22,183
    1,728
    Happened across this E-book page:
    http://www.allaboutcircuits.com/vol_3/chpt_4/2.html
    The first Figure (c) is incorrect. The PNP transistor will act as a voltage follower (common collector) rather than a switch. The load (lamp) needs to be between the source negative side and the transistor's collector.
    Re-use of figure letters on the same page is not a good idea, as it can lead to confusion.
    The 2nd figure (a) and (b) are not correct. The transistor will not saturate; Vce will not go below around 0.63v, or the Vf of the BE junction.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    This was brought up a long while back. I tend to agree with Wookie on this one.
    (c) needs the transistor and the battery flipped.
  3. eblc1388
    Nov 28, 2008
    1,542
    102
    No. No. It won't make any difference. :(
    (c) needs the transistor and lamp flipped, as below.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    It won't?
    I disagree, and it matches the illustration better.
  5. eblc1388
    Nov 28, 2008
    1,542
    102
    It take me a while to find out what exactly you disagree. :)
    You would like your version of the diagram better, which is just the same version as I posted, albeit drawn differently.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    You stated this was incorrect. In what way is it wrong?
    I redrew it verbatum to the statement you disagreed with.
  7. eblc1388
    Nov 28, 2008
    1,542
    102
    I'm sorry Bill, my mistake.
    Its my poor understanding of the word "filpped" that has caused all the trouble.
    I had taken it to mean "swapped" but then I realise there is difference between flipped and swapped.
    See, I have made the same mistake again above in the reply: quoting myself:
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    No problem, writing text doesn't let nuances that speech does come through.
    I think we are all agreed, problem verified.
  9. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    I have updated the image at ibiblio.org by flippping both the pnp and the battery.
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Existing image:
    Proposed change:
    At that particular stage, it may simply confuse a new reader to introduce the concept of Ib=(Vcc-Vbe)/(Ic/10) for forced beta. However, it's rather incorrect to call a transistor saturated, when the original circuit's Vbe could be reduced by increasing Ib.
  11. Markd77
    Sep 7, 2009
    2,803
    594
  12. Wendy
    Mar 24, 2008
    20,772
    2,540
    I think if you look again that problem has been fixed.
    Compare the illustrations shown at the beginning of this thread to the current ones.
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    Sheesh, I missed post #10. I think Sarge has nailed it again. Should have been in a different thread, but it is a problem.
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I just sent a note to Dcrunkilton to ask him to review and update the page.
    Hopefully, he will update the schematics and at the same time correct the figure numbers, so that there are not duplicate references to (a) and (b) on the same page.
  15. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    Thanks SgtWookie,
    I have changed the image at ibiblio (03078.png 03078.eps)
    I don't think that changed images at ibiblio get detected (like changed text) . Therefore, we may need to inform Dave or Jjrap of the changed image.
    Dennis Crunkilton
