The target device is not ready for debugging. Please check your configuration bits
Discussion in 'Embedded Systems and Microcontrollers' started by Guinness1759, Jan 17, 2011.
  1. Guinness1759
    Dec 10, 2010
    64
    #include <pic.h> //HI-TECH C header file
    __CONFIG(WDTE_OFF & CPD_OFF & FOSC_ECM & LVP_OFF);
    /* Watch Dog Off, Code Protection Off, */
    //********************** CONSTANTS, VARIABLES ********************************
    #define _XTAL_FREQ 400000 /*Define the Chrystal frequency for the
    //Hi-TECH C __delay_ms() function in Hz used in the pause function below */
    //********************** MAIN FUNCTION **************************************
    int main()
    // My code, it's blinking an LED
    I've also tried setting the FOSC_XT instead, but that does not work. I have a 2 MHz crystal oscillator (ECS-20-20-1X) set between pins OSC1 and OSC2. I'm using a PIC16F1827.
  2. spinnaker
    Oct 29, 2009
    5,114
    1,195
    Assuming you want to debug:
    You need to first compile with debug, then program using the Debug menu.
    And this should be in the embedded forum.
    Guinness1759 likes this.
  3. Guinness1759
    Dec 10, 2010
    64
    Thanks, now I'm getting past that error. I didn't realize that I had to program it in debug mode.
