I am trying to project a switched mode inverter for a UPS that I am building. However I need some tips for select some right components. For example. What switch regulator should I use in the full bridge inverter and in the half-bridge converter?
In the upper-left side of the diagram I put a Half-Bridge converter to elevate the 24VDC to 170VDC and after that I use this voltage to power the full bridge inverter and in the output I put a pi filter to remove the harmonics.
The desired power for this inverter is 400W.
I like to hear some tips for my design.
Thanks,
FBorges22
Thanks,
FBorges22
