The EM-Drive people may not be able to afford it. I do wonder how much they charge an hour for an empty chamber with "nothing" in it.That' where they should test the EM-Drive.
The company my dad worked for, which was an air compressor manufacturer, had a sign that said, "Air is free, until you try to compress it."The EM-Drive people may not be able to afford it. I do wonder how much they charge an hour for an empty chamber with "nothing" in it.
That's just barely high vacuum today in chip manufacturing. We easily pump to 10 -12 Torr on some FE-SEM systems with Ion pumping and most Ion beam systems base vacuums are close to 10 -8 range inside man sized chambers after a re-qualification of operation. What's truly impressive about the SPF facility is the pumping speed to that vacuum level. The still use old fashioned oil diffusion pumps we studied long ago at the Varian Stanford Facility.NASA Space Power Facility.
It can achieve vacuum down to 1 µTorr, which is pretty damn hard under the best of circumstances in a small volume.
I was speaking in regard to us common folk. I deal with vacuum quite a bit -- "virtual" leaks are a pain to diagnose and fix.That's just barely high vacuum today in chip manufacturing. We easily pump to 10 -12 Torr on some FE-SEM systems with Ion pumping and most Ion beam systems base vacuums are close to 10 -8 range inside man sized chambers after a re-qualification of operation. What's truly impressive about the SPF facility is the pumping speed to that vacuum level. The still use old fashioned oil diffusion pumps we studied long ago at the Varian Stanford Facility.
http://www.chemassociates.com/products/findett/diffusion_pump.pdf
SPF Vacuum Pumping System
UHV pumps
- Five 2200 liters/s turbopumps
- Sixteen 48 in diameter LN2-baffled electrically heated, oil diffusion pumps (pumping speed - 700,000 liters/s)
- Ten 48 in diameter cryopumps with vacuum isolation gate valves (pumping speed - 600,000 liters/s)
- Pumpdown Times:
Atmospheric pressure to 20 torr: 2 hrs
20 torr to 10-3torr: 4 hrs
10-3 torr to 10-6 torr: 2-6 hrs
https://www.duniway.com/images/_pg/ion-pumps-operation-applications.pdf
