The question is driving me mad...
Discussion in 'General Electronics Chat' started by sanju, Jul 12, 2008.
  1. sanju
    Jul 12, 2008
    When I find a current in a delta connected load the answer I get is 28.41 <angle 110.92...while the answer in text is 28.41<angle -69.07
    R both the answers same or different.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Your answer is 180° out of phase with the correct answer.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    As evidence of sgtwookie's correct assessment, if you add the phase of the correct answer to the value you have calculated you will get 180 degrees.
    hgmjr
  4. silvrstring
    Mar 27, 2008
    159
    Can you post the problem and your work?
