I had the similar requirement for Flow meter application before...
I had done only paper design work....
My requirement was -
Input-
85VAC-265VAC 50Hz
18VDC-36VDC
Output- 15W
Means i wanted to implement a single SMPS design which works with above range.
I wanted to give free hand to customer that whether he power up the flowmeter either by 230VAC or 24VDC at a time.
Mod note:
Please don't hijack other member's thread, now you have your own.
This thread was split from --
30VDC to 480VAC Input range to 24 V 10 Amp powersupply.
Input-
85VAC-265VAC 50Hz
18VDC-36VDC
Output- 15W
Mod note:
