I am confusing that why so many SMPS manufacturer's application notes recommend placing thermistor after fuse but before varistor.As there is a likelihood that the thermistor would explode in a surge test.Just change the placement of thermistor and varistor can solve the problem simply.If use the recommended circuit(thermistor place before varistor),there must be using higher level thermistor for take the surge test.Please give me a hand to solve my confusion.Thank you very much.
