A few notes - just my opinion but I think a simpler design to get started will be better. Additional complexity can be added in future updates...
The powder feed system could be simplified by using a gravity drop and screw feeder instead of a hydraulic ram. Just drop on the leading edge of the screeding ram and it will be easily distributed, similar to existing powder metallurgy (press and sinter) processes.
Gas enclosure will be fine for non-reactive metals but to really remove air that is entrained in the powder, you will need to apply vacuum and then back-fill with inert gas. Most important for titanium (i still think titanium and all accessories to accomodate titanium should be left off of a base verison).
Do you really want to use three lasers? I am guessing that controlling them all to the same point will likely be more work (and yield lower resolution) than a single higher powered laser.
