The LED(SMD) on the PCB is making ticking noise when it is turning on/off. What could be the reason?
Discussion in 'General Electronics Chat' started by supermankid, Nov 24, 2014.
  1. supermankid
    May 26, 2013
    36
    The LED(SMD) on the PCB is making ticking noise when it is turning on/off. What could be the reason for this noise? (It is like a small...."chlick chlick").
  2. blocco a spirale
    Jun 18, 2008
    1,462
    370
    How do you know the noise is from the LED?
  3. mcgyvr
    Oct 15, 2009
    4,793
    976
    Is there a "relay" on that board that might be clicking?
  4. GopherT
    Nov 23, 2012
    6,328
    4,069
    I doubt it is the LED unless something very weird is going onwith thermal expansion and a bad solder joint is clicking. Check for a relay (magnetically activated switch) as McGyvr suggests above.
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    a capacitor might be doing the clicking too. in fact is more probable than the led.
