GetDeviceInfo
- Joined Jun 7, 2009
- 2,192
most (if not all) municipalities have the right to implement laws that protect the populace. One of the most basic laws in North America is adherence to standard building codes. Although you could build a structure to any specificiation, your local bylaws likely dictate that certain structures must be built to some minimum code, which a permit and inspection are part of the process.
The application of the Electrical code is no different. Installations must be permitted/inspected/approved, as are any modifications. Municipalities often hold the right to inspect any installation connected to the utility, and can issue an order to comply or disconnect.
