the johnson counter
Discussion in 'General Electronics Chat' started by reymund, Oct 6, 2008.
  1. reymund
    Sep 23, 2008
    23
    hello,
    sir basically i know how does the 4017 johnson counter operates, but i want to know if this particular cmos can count form the msb to lsb and vice versa.. thank you.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    No, it just counts one way.
    If you want something like that to go both ways, look at using something like a 74154 demux/decoder driven by a binary up/down counter.
  3. reymund
    Sep 23, 2008
    23
    sir if i apply the up down counter to the 74154 does it counts up and down automatically???... thanks for the info by the way.
  4. mik3
    Feb 4, 2008
    4,846
    63
    Check this counter here
    http://www.robotstore.com/download/12925.pdf
    It can count up/down depending on the voltage on a single pin. Also, you can choose binary/decade counting.
    For more counter chips search in google for up/down counter.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A 74154 is a decoder/demultiplexer. It has no counting function at all.
  6. Bernard
    Aug 7, 2008
    4,240
    414
    I like this up down counter: CD 4029; BCD or binary ,jam inputs, single up/down control. If you connect carry out to the toggle input of a flip-flop[ CD4013 etc.] & connect Q out to up/down of 4029 it should count up & down if clock pulses are applied to clock input. A CD4515 decoder will give 16 outputs with binary in put.
