The Jacob Shekel circuit analysis method - Need help from The Electrician!
Discussion in 'General Electronics Chat' started by bitrex, Oct 24, 2010.
  1. bitrex
    Dec 13, 2009
    79
    I was reviewing the method of circuit analysis that The Electrician sent me some files about a while back, using admittance matricies. Unfortunately, I'm somewhat confused about how the admittance matricies for the transistors in a circuit were developed - if The Electrician is around, could you walk me through how the matricies for the transistors were derived in the following: http://forum.allaboutcircuits.com/attachment.php?attachmentid=11648&d=1250840496
    I have a PDF specifically on the topic that you sent me, but unfortunately some of the figures in it are hard to read from the scan and I'm having a difficult time translating the matricies given in the document into the ones you derived, regardless.
    Thanks in advance.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
  3. bitrex
    Dec 13, 2009
    79
    Thanks for the reply, though I'm not sure that the transformation matrix is what I need. I'm wondering how to relate an indefinite admittance matrix such as the one at the top left of this link:
    To the various transistor parameters. Essentially I'm trying to figure out why the values in the matrix are what they are.
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    Well, here you have matrix for CE amplifier
    Y = \left[ \begin{array}{2}\frac{1}{h11} & \frac{-h12}{h11}\\  \frac{h21}{h11} &  \frac{h11*h22-h12*h21}{h11}\end{array}\right]
    And
    H11 = (β+1)*re
    H21 = β
    H22 = ro
    H12 = ?? I don't know
    And if emitter in not grounded the re need to be add.
    So
    1/H11 = 1/(β+1)*re
    H21/H11 = β/(β+1)*re
    And so on.
  5. The Electrician
    Oct 9, 2007
    2,300
    335
    Here's some explanation of how to deal with transistors.
    Let me know if you need more.
    bitrex likes this.
  6. bitrex
    Dec 13, 2009
    79
    Thank you! To use this method it looks like I need to know the h parameters of a transistor in its various configurations - common emitter, common base, etc. Is there somewhere I can find such a list?
  7. The Electrician
    Oct 9, 2007
    2,300
    335
    You can just do what I mentioned in the first image above, where I say:
    "Now that we have an indefinite matrix, we can get the definite matrix for the circuit with a different node grounded. Just delete the row and column corresponding to the node to be grounded"
    So, you can start with, for example, the definite matrix of a common emitter configuration, convert it to an indefinite matrix and then delete the node corresponding to the base and you will have a 2x2 definite matrix for a common base configuration.
  8. bitrex
    Dec 13, 2009
    79
    Great! I'm going to start practicing with this method, using Maxima for the matrix manipulations.
